Ac delete
Hi all
Was wondering if i could do an ac delete on my 53 multispace i have currently removed the aircon pump and purchased tbe smaller belt an idler but not sure if its doable thanks in advance
The heater matrix is different on AC models, probably a major job to remove & replace? If you have no compressor, that'll be the major work done.
(31-05-2019, 06:45 AM)cancunia Wrote:  The heater matrix is different on AC models, probably a major job to remove & replace? If you have no compressor, that'll be the major work done.
Thanks for replying thought it would be too gd to be true , iam having an issue with the belt running on the edge of the ac pump pulley  ,when looking up the pulleys the air con pulley seems out of line from the rest , its had an engine swap recently so goin to put the other pump on see how i get on
Last Post: BigVtwin996
Today 12:10 PM
Eolys replacement tank
Last Post: jw4821
Today 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
