Easy sump removal on DV6
Thumbs Up
Just thought i'd share this to save someone else the pain
I completely wrecked my sump and gouged the aluminum casting pretty bad whilst trying to get the b****rd off to re-gasket a small corner that was leaking Angry couple of hour job turned into 10 hours of swearing.
Upon fitting the new one I saw the two studs that are at either end of the block have a tiny spline cut in the top of them so when you undo them the flange pushes the sump off! Easy  Big Grin
Also: Loosen the cat & heat shield, don't have to remove it completely but it will make it so much easier
[-] The following 2 users say Thank You to munkey for this post:
  • cancunia, saskak
Eolys replacement tank
Last Post: Harrythephot
Yesterday 12:02 PM
Yesterday 10:27 AM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: stu76
12-08-2026 05:41 AM
Last Post: BigVtwin996
09-08-2026 12:10 PM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
