Tail lights
Hi I wired in 2 led work lights to my van got the power from the reverse light power with an inline fuse . Basically when I turn them on they work fine but when I plug the tailligh back in they all go of including the reverse light . But if I switch van of then on it works as long as the led lights are disconnected.  Any ideas I am thinking maybe to much power for the taillight to take . It's a 2013
hi, are the lights canbus approved...........some led lights will give u problems......
Fit a towing relay then they'll work Ok - that will need a battery feed though you may all ready have the wiring in place lots on on the forum with that info,
then you could use that an not have to have the ignition on.
I've got an extra light fitted on the tow bare like this works a treat
theres a warning not draw more that 10mA extra on the lighing loom ....
Jake
It may be a stupid question but is the LED lights in the holder the right way?. They act like a one way valve , flows one way but not the other .
Thinking it may have something to do with the strange behaviour of the lights.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Not this time if ionly it was that simple  Wink - the BSI knows hoew much curent shoule be taken by the revesing light and if its more will disable it ... thats why the revesing light or the work lights work but not both .. hence the need toa toeing relay or other power feed
Someone has kindly smashed the rear offside lenses on my 2014 multispace. Can't find the correct replacement locally or onli e. Local citreon dealer is still closed. Anyone help plz?
eBay mate, loads of them on there for the car and van style B9 lights. Usually about £45 so have a look. Don't buy from a dealer, They charge a fortune!
triangle light
Last Post: norm1
Today 12:20 PM
Yesterday 04:32 AM
Last Post: Jed Clampit
12-06-2026 10:44 PM
My Berlingo Multispaces
11-06-2026 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
