Air filter pipe
Belingo xtr 115 2011 . Hello while tightening up my exhaust shroud to try and stop an annoying rattle which happens at 1500 to 1800 revs  I noticed my air filter pipe was a bit lose the one coming from the air filter to the turbo are they push fit or are they supposed to have jubilee clamps on them ?
The have a clip where its pushes onto the turbo inlet from the air filter, some have a jubilee and some have a spring clip.
(04-06-2019, 11:33 PM)I polar Wrote:  The have a clip where its pushes onto the turbo inlet from the air filter, some have a jubilee and some have a spring clip.
Thanks I polar mine has no clamps  on both ends  I will sort that today
20-07-2026 02:51 PM
Clocks dropping out
Last Post: Micklew
18-07-2026 09:29 PM
air con
Last Post: magoo1
18-07-2026 04:56 PM
triangle light
Last Post: Buki
18-07-2026 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
