  • 13 Vote(s) - 2.77 Average
Here's one for the tuning/mod guys...(Duamo?)
OK, we know that the standard turbo-charger on the 1.6 HDi has it's share of problems mainly connected, it seems, to the oil feed to the turbo.
The new MkIII 110 has a different turbo which is a 'twin-scroll' type.
If the normal 1.6 turbo fits the new model then can the new twin scroll turbo be retro-fitted to the MkII 1.6 engine?? Confusedtudy:
hi jeffers. ive come across this problem earlier in the year. my friend had a Citroen C4 or C5 not sure witch but it had the same engine and turbo as the berlingo MKII 1.6 HDi. he was forever having problems with his turbo, all down to the oil feed pipe. long story short he got rid due to repetitive problem. i recently got a new 2011 MkII berlingo this year and my mate had a look within the engine bay to find the same engine as his C4/C5 But with one Change. a Different oil feed pipe for the turbo. Have Citroen cured this fault ? its looks Possible. if you like i can post a picture of the new MKII engine.
hope this has been helpfull
1.6 HDi Berlingo van , 2011 plate
Thumbs Up
Interesting reply BL. A piccie would indeed be good.
I don't have a problem at present but as both the old and new shape
Berlingos have ostensibly the same 1.6 engine I didn't see why the new twin scroll turbo shouldn't, with minimal modification, be bolted on to the older set-up.
Dont know alot about the 1.6hdi but do you know what turbo is in them both.? Probly both a garrett GT15 if they are they should be interchangble even with a slight modification anything is possible. Ill do some research.
Also worth checking on ECU as this controls boost etc on these
Last Post: JPCoetzee
Today 10:34 AM
Last Post: jw4821
Today 08:48 AM
13-03-2026 09:14 PM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
