08-06-2019, 08:54 AM
i have a 55 plate Berlingo 1.9 diesel van. Driving out of the driveway the other morning, the L/H side front spring snapped and pierced the tyre.
I arranged to have both front springs replaced and when the L/H side strut was removed we found that the bottom spring plate on the shocker had detached
most likely causing the spring to fail. The shocker was replaced along with the spring.
While the struts were off the top mount's and bearings were inspected and these seemed fine, Both drop links were renewed as well. However when both struts were refitted, there was a slight twang noise coming form the R/H side strut when initially turning the steering wheel.
we jacked the van back up and confirmed the noise was from the top mount, whilst jacked up slackening the main lock nut on the top mount under the bonnet makes the noise stop.
As a precaution the entire top mount and bearing have been replaced. However on refitting the strut and testing, the noise still remains.
I have confirmed that the noise is from the top mount, does anyone have any idea the cause of this and any remedy seeing as everything has been renewed and fitted correctly.
