Threads: 68
Thanks Received: 26 in 22 posts
Thanks Given: 22
Hiya all.. I have fitted a permanent power supply for my dash cam, I soldered the connections directly to the cigarette lighter and ran the cable around the end of the dash, up the inside of the inner trim and under the roof liner, I have noticed a drop in radio station quality, I recon it's the route of the cable, is a dash cam power cable going to cause an issue with radio quality ? The aerial lead runs down the same route of the power cable.. If it is the issue, can I just cover the aerial cable or power cable with tin foil ?
Black Hyundai i30 1.6CRDI 2011
Silver 1.9D Mutispace desire 2004 DW8B non Turbo..
White 1.9D Van 2005 DW8B non turbo..
Silver MGF 1.8 16v 1999
Threads: 41
Thanks Received: 405 in 362 posts
Thanks Given: 134
31
I too had the same problems after doing the same as you .
Tried all of the 12v to 5v supply droppers hoping to sort it out but didn't work.
In the end I took the original cable and modified it. I removed the plug but kept the circuit board inside it and wired that directly into 12 volts . Got a little plastic box off ebay and used that as a housing for the board and a bit of twin core cable.
I didn't try your idea of wrapping the wire in foil which may work as it should cut down on interference from the feed cable.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 41
Thanks Given: 134
31
I tried those boxes ,ordered two with the usb end , one didn't work and the other caused interference.
Just to see the response from the supplier I complained about the dud one and was asked to send a photo.! Never heard any more from them .
Thanks Received: 3 in 2 posts
had same problem with my dash cam , used ferrite core i got of ebay , just clamped ferrite core to cable as close as possible to dash cam
