A little review of my camper build. Tried to keep it short. Just ask if you would like more info.
I must thank Gravity and his B9 Camper build thread. I basically used his blueprint, very helpful! His thread is here https://www.berlingoforum.com/thread-16358.html
First item I made was my own take on amdro rear window cupboard. Pleased with how it came out. (Inside of window was covered with reflectix)
![[Image: IMG-20180926-172902.jpg]](https://i.ibb.co/x16nPMn/IMG-20180926-172902.jpg)
![[Image: IMG-20181002-155244.jpg]](https://i.ibb.co/85xTQc4/IMG-20181002-155244.jpg)
Went on to build the rear boot section. Went with a full length draw on the left side for stove, cutlery and storage. The right side is half sized pull out tray to hold water container and rest a cut out for storage tray.
![[Image: IMG-20181118-152818.jpg]](https://i.ibb.co/S7GzCN7/IMG-20181118-152818.jpg)
Added the hinged bed fold out panels. I left in the factory seats to give the bed more support
![[Image: IMG-20181119-145612.jpg]](https://i.ibb.co/xXTXWxd/IMG-20181119-145612.jpg)
Test of the install in seat mode
![[Image: IMG-20181119-151112.jpg]](https://i.ibb.co/M2qXrQh/IMG-20181119-151112.jpg)
Same ebay foam to make bed as gravity used - thanks! Just gut with large scissors
![[Image: IMG-20181206-141408.jpg]](https://i.ibb.co/pxLR988/IMG-20181206-141408.jpg)
I used online guides and my brothers advice from his solar leisure battery install. Ebay 80w solar panel. It is flexible but a solid one might have been better in hindsight
![[Image: IMG-20181207-134759.jpg]](https://i.ibb.co/44cpKwC/IMG-20181207-134759.jpg)
Below is the leisure battery, solar controller, fuse box and the fridge in the background. (hadnt finished wiring in the picture. Split charger and additional wiring added after picture)
![[Image: IMG-20181219-121439.jpg]](https://i.ibb.co/9HLcwms/IMG-20181219-121439.jpg)
![[Image: IMG-20181219-121518.jpg]](https://i.ibb.co/QXP61Rp/IMG-20181219-121518.jpg)
White led string lights in front area of the van. The rear has an ebay RGB remote led light setup
![[Image: IMG-20181219-160733.jpg]](https://i.ibb.co/qMpG0BQ/IMG-20181219-160733.jpg)
