Another central locking problem
I went out to the car today having not used it for about a week, pressed the button on the key and heard a weak click but not the locks opening as they usually do. I had to use the key manually to open the drivers door and the car started alright. I've checked all the fuses in both boxes and all are good, the lights flash as if the doors are working but the solenoids are not clicking but if I open the rear doors manually then the locks will close again but not reopen. I charged the car battery and put a new battery in the key fob, did a BSI reset and still the same is happening. Any ideas, and where is the receiver for the signal from the key fob ? Any clues gratefully received before I start taking the doors apart.
Does the button in the dash work?
(14-06-2019, 04:27 PM)cancunia Wrote:  Does the button in the dash work?
It only does the same as the key, the two rear doors will lock but not open and the fronts and boot are just a faint click but not doing anything. It's baffled me because they are obviously getting the signal just not operating.
Could it be the servos and lock mechanisms are a bit stiff and need a bit of lube. Not sure what type and age of your vehicle but if its an M59 the controller for the central locking is down in the drivers footwell by your right foot. You could check out the connections for breaks and resistance. If I remember right its a green coloured box.
  • ffrenchie
(14-06-2019, 06:45 PM)Tomcat3 Wrote:  Could it be the servos and lock mechanisms are a bit stiff and need a bit of lube. Not sure what type and age of your vehicle but if its an M59 the controller for the central locking is down in the drivers footwell by your right foot. You could check out the connections for breaks and resistance. If I remember right its a green coloured box.
I'll have a look at the controller when the weather picks up, it's really peeved me today so it's going to be used manually for a day or two. It's 16 years old so might be due a bit of attention.
There's also a green coloured box, screwed to the underneath of the BSI just above the accelerator pedal. It's for the driver's window to go down with a single touch on the switch.
See post #12
https://www.berlingoforum.com/thread-18150-page-2.html
If the dash switch is doing much the same as the key, chances are the problem is somewhere in the wiring as mentioned in a post above. I'm not sure if the central locking solenoids are activated via relays in the BSI? If so, it may be worth starting there to make sure all the wiring plugs are seated well.
Forecast looks a bit better for tomorrow I'll have a look for the green box and see if anything is disconnected or damp has got in. It's like being back in the stone age having to use the key every time Big Grin
(15-06-2019, 07:30 PM)El Wrote:  pronóstico de ffrenchie se ve un poco mejor para mañana. Voy a echar un vistazo a la caja verde y ver si hay algo desconectado o si ha entrado humedad. Es como estar de vuelta en la edad de piedra teniendo que usar la llave cada vez.Big Grin
De acuerdo, nos da los datos para las generaciones futuras que tienen problemas similares como los suyos .
Leaking windscreen or aerial
Yesterday 08:50 PM
Apple Carplay
02-04-2026 01:26 PM
