Thanks Received: 3 in 2 posts
hi there
was wondering if any one can help me with two permanent fault codes
1, turbo pressure electrovalve control flow too low
2,preheating relay circuit relay supplied and plugs never supplied
any help with these faults will be greatly appreciated
sorry should have put fault codes on message
1. p0299
2. p1351
Threads: 123
Thanks Given: 250
34
The first seems to suggest that the airflow is lower than expected, it could be a faulty or dirty sensor. The airflow & temp senors are in the doseur / throttle body just after the intercooler. The flow sensor on mine was quite mucky with oil, I cleaned it with brake cleaner IIRC, there are other posts on here about cleaning them so maybe worth a read.
You can check if the boost is ok via the OBD reader with the Torque app or similar.
The second fault code is maybe the glow plug relay, mine has the same fault and I couldn't find anything wrong so I've left it alone. So long as the engine starts & runs ok, I'm not too fussed.
