Threads: 20
Thanks Received: 7 in 7 posts
26-06-2019, 02:48 PM
(This post was last modified: 26-06-2019, 02:49 PM by magoo.)
Have done a search on here and the web but no joy..
Intermittently when putting the cap back the key will not turn, have always managed to free it but not seeing how.
Worried that eventually the key won't free so can anyone tell me if there is something to look for which might be worn/broken when the cap is off?
Or is it a replace job?
Thanks.
Multispace B9 2009 1.6HDi
Threads: 13
Thanks Received: 44 in 29 posts
Thanks Given: 29
If it's a similar problem that I've had in the past, when in place try pressing the top edge of the filler cap, then turn the key. Works for me.
Sent from my SM-T810 using Tapatalk
2013 Berlingo XTR 1.6 HDi 90 (WAV)
2016 Partner Tepee 1.6 Blue HDI S/S (WAV)
2020 VW Caddy Maxi Life 2.0 TDI (WAV)
Threads: 54
Thanks Given: 147
7
I've had a similar concern, I think fuel vapour dissolves any lubricant in the lock mechanism. What I've done is, with cap removed and a small screwdriver in the key slot to hold the sliding cover back I've allowed a couple of drips of light oil (3 in 1 type) to run down into the lock. Next I've inserted and removed the key a few dozen times to work the oil around, locking and unlocking the cap each time. Finally ensure the key is as free from oil as possible so that you don't transfer oil onto clothes etc.
Matt
previous
2016 1.6 HDi 100 XTR Grey Met
2010 1.6 HDi 105 XTR Gold Met
Threads: 42
Thanks Received: 409 in 366 posts
Thanks Given: 137
31
A graphite aerosol squirted into it helps and doesn't evaporate. aldi had them for a while. It leaves a covering of graphite in the lock mechanism.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 20
Would silicone lubricant be good to use ?
