Weird noise from my 75hp HDi 2009 + Aircon issue
Hi guys, I'm new here.
Basically, as I was driving (40-50km/h, around town), the car started making an awful noise together with a faint vibration. The feeling was as if something was hanging from the car and grinding on the asphalt. The engine temperature went up to 100 deg. celsius, and there was a faint clutch/brake-like smell. After I safely stopped and cut the ignition, the (very) annoying noise persisted for 5-6 minutes. When I popped the hood, I couldn't locate the source of the noise. The best guess I have is the radiator fan, but I'm not the most skilled or knowledgeable mechanic ever. Any help from y'all more experienced guys (and gals) would be very appreciated.
Plus a (fairly) minor (it would've been minor if it wasn't 40 deg celsius outside) complaint about the A/C
It seems to cool normally when the fan is at 1 or 2, but when I turn it to 3 or 4, the air becomes hot in a few seconds (A/C button pressed all the time, manual A/C). Is this possibly related to the first issue?
Welcome.
Just guessing... If the noise persisted while you were stopped with the ignition off, chances are that is was the radiator fan as you suspected. Your aircon is probably running low on gas, it will operate down to about 2bar pressure but the lower the pressure, the more the system has to work (making the engine hotter) & the less effective it will be.
  • red.berlingo12
(03-07-2019, 04:21 PM)cancunia Wrote:  Welcome.
Thanks a lot dear sir!
Newbie
Last Post: Vmkst
Yesterday 08:48 PM
MyBerlingo App Service History
Last Post: Requiem
13-02-2026 10:43 AM
Mk 3 K9 blower not working
12-02-2026 04:57 PM
Diagbox 9.91 free download
Last Post: Slowmo
11-02-2026 06:29 PM
Last Post: Slowmo
11-02-2026 06:26 PM
» Replies: 29
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
