P1199 fault code
Hi, i have this fault code p1199, the problem only seams to appear when it is hot
Like the weather we have had the last few days,
The van runs fine till you start to go up any sort of incline and put a bit of load
On the engine and then the van goes into limp mode, this is a problem that has gradually Got worse, since new the van has always had an episode every now and then of just randomly cutting out when you change gear from say 3rd to 4th it is like you have taken your foot off the throttle but it is pushed to the floor with it to only slow down and stop which is quite annoying,  i have changed The fuel pressure regulator on the pump and changed the filter
The fault reads
“P1199 Fuel high pressure regulation. Lack of fuel prevention strategy
Intermittent”
Van is 2015 non ad blue
Any fresh ideas or info, i would be most grateful
Thanks in advance
Today 08:03 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
16-09-2026 09:50 AM
» Replies: 16
removing front strut
16-09-2026 02:07 AM
Strut Top Mounts
15-09-2026 07:58 PM
