Threads: 32
Thanks Received: 3 in 3 posts
Thanks Given: 18
Have had the Berlinvo about a Month. Mainly been doing short Journeys. Today took it on the Motorway.
All fine for the first ten minutes. Then at around 70 mph. It started to hesitate happened about every 30 seconds. I noticed when I dropped to 60, mph the hesitation was gone. I've had an anti pollution fault warning the last couple of weeks. I'm wondering if it's the Fuel Filter. Was going to change it along with Oil Air filterr
Threads: 67
Thanks Given: 237
50
Always best to start from a known datum and new filters is the best way to begin, I'd also throw a strong dose of fuel injector cleaner into the tank and give the car a decent thrash up the motorway.
After that you may well be sorted.
Serieal Berlingo owner
Threads: 123
Thanks Given: 250
34
Anti Pollution Fault could be the MAF, what engine is in your Berlingo?
In any case, as noted above, changing the filters & some injector cleaner is probably a good starting point.
Threads: 32
Thanks Given: 18
Thanks for the replies
Have ordered a fuel Air and oil kit off ebay.
Soon as that arrives I'll get everything done.
It's the 1.6 HDi 90 BHP
I was thinking of the Forte fuel cleaner expensive stuff but not sure of the alternatives
Ian
