  • 8 Vote(s) - 3.5 Average
BSI at fault??
Hello
Had a quck look on forum for answers to this ,so sorry if i've missed it.My vehicle is a 2000 Multispace 1400 petrol and the problem i have is that since i've had the car the central locking,rear wiper and interior heater have not worked.The first two i can live with but now the colder weather is upon us i need the heater to work to clear the screen and keep my old bones warm!
I have checked all the fuses and the fan worked when tested by a mechanic friend who seems to think it could be the BSI unit which is at fault.Any suggestions??
Cheers
You can perform a reset on the Berlingo by taking out a big fuse, think theres a guide on how to do it on a ecu repair site, begins with a B but cant remember it. It may work.
[-] The following 1 user says Thank You to tommyberlingo for this post:
  • chad41
If you have an electrical feed to the rear wiper it's most likely a seized/worn wiper motor. Had to replace mine on a 2002 model. Took it off and striped it down but the gearing was u/s. Hopefully your motor will be bolted on. Mine was poprivited with huge rivets that I didn't have. Local garage did it.
Griff
Landmark
Ex 1.4 Berlingo Multispace
[-] The following 1 user says Thank You to Landmark for this post:
  • chad41
I don't think that the heater would be in any way controlled by the BSI.
Possibly the blower fan may be but I can't see why it should be. Maybe another Citroen quirk.
Even with no fan assistance you should get some warmth.
Today 01:49 PM
Yesterday 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
