Hi
Any last tips before my attempt to change the timing belt on the 2.0 hdi? I found some helpful tips from the old threads:
1) Tensioner bolt should be renewed with an OEM unit or it could snap.
2) Water pump should be OEM or it could start to leak.
3) I read from frenchcarforum that those electric heaters on the coolant houses could cause trouble while bleeding the coolant system. If there is air trapped then they could even start to smoke and later they will start to leak. So it is better to remove fuses while bleeding.
The flywheel locking tools goes exactly where? Do I need to remove the bottom flywheel cover ? I do not mean the timing hole which is behind the starter motor but the tool for holding the crank when undoing or tightening the crankshaft pulley bolt.
