21-07-2019, 01:43 PM
Hi All,
I have another problem with my berlingo not sure if it is part of the same problem i had with my DPF? Anyway i got the DPF replaced for a new citroen one 6 weeks ago and now i seem to be having turbo issues. Car is sluggish if loaded turbo seems to lag and not kick in properly till 1900 rpm and its using oil there is also a swishing noise from the turbo when driving it. This noise has always been present but was always very quite and hardly noticed now its noticeable when driving when the windows are closed and gets louder the faster i drive.
So since this has occurred i now have a noise coming off the car from the engine area at idle. If the car has just stopped there is no noise just usual from the engine but after 20/30 seconds of idling there is a noise like a fan is working becomes apparent. However the cooling fan is not switched on and the aircon is off plus no regeneration. Is there a hidden fan unit on this cooling something else out the road of is this something else??? If you rev the engine a we bit once it starts it also switches off and returns after a short period of idling. Not sure if its me being paranoid and its maybe been something there all the time and im just noticing it with the turbo issues. I most definitely think my turbo is on its way out so getting it in to the garage to see what the deal is with it. Any advice on this would be appreciated.
