  • 7 Vote(s) - 2.29 Average
Drive Belts
Hi have just had to replace the steering pump drive belt as it had drifted on the pulley and snapped. The new belt will not run in line so something is out of alignment any ideas?
That belt does the alternator as well.
And a/c if you have it ?
It s a fairly complex route so perhaps something has become bent eg an idler pulley causing the first belt to fail.
Its a polyVee belt so I can't see how it can "drift". Its locked onto the alt and the crank pulley.
'98 D 800 van Big Grin
Thanks for your reply I've just checked the alignment and it seems to be the tensioner pulley I've shimmed it over and initially it seems to be working I'm going to take it out for a run I'll report back when I return.
Seems to be ok but I'll keep an eye on it.
Diagbox 7.57 download
Yesterday 09:13 PM
Yesterday 05:26 PM
Air filter box removal
Last Post: Harrythephot
07-03-2026 11:03 PM
Berlingo undertray
07-03-2026 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 04:25 PM
06-03-2026 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
