25-07-2019, 01:28 PM
As per the title I have a 2004 1.9D Multispace that has left me stranded this morning due to a duff gear linkage.
Putting the car into revers has been taking a little more effort than usual recently and this morning when I went to reverse out of a parking spot the gear lever became properly stuck when I tried to go into 1st. After giving it a bit of brute force the gear stick moved but the car was still in reverse and I ended up having to ask someone to push me back into the parking spot so I wasn't block the car park.
I had a quick look under the bonnet and could see the gear linkage had popped off it's ball joint but being on my own and having no tools I ended up having to get the RAC out and he managed to get it all back together and I was able to nurse the car the 20 odd miles home.
The car will change gear OK but the ball joint pops back out if I try and put it in reverse so it's not really usable at the moment. I've had a look for replacement linkage parts but everything I see is for the 3 short link rods which on my car are fine. It is the longer selector rod that goes under the car and connects to the gear stick in the cab, it has popped off the ball joint that is attached to the transmission housing.
There is a link to a diagram of the affected part below.
https://photos.app.goo.gl/G4XYoa2MAFXZ1yrc8
Does anyone have a part number for this particular part or am I able to buy the bushing seperately and press it in myself?
