Threads: 23
Thanks Given: 46
5
Lucky you, whoever ordered it new obviously selected all the add on packages.
The following 1 user says Thank You to Trevor for this post:1 user says Thank You to Trevor for this post
• gotoberlin
Threads: 20
Thanks Given: 7
15
You'll be blown away by the latest edition.
Lane guidance - steers you back into the centre between two lanes
City braking - for that odd time some idiot walks out behind a parked car, automatically brakes for you.
Autolights and wipers - full beam lights come on auto on dark roads and turn off when it senses oncoming traffic
Auto speed limit - dead handy through road works, otherwise its not set to auto
Adaptive cruise control on the auto models - keeps a 2 second gap between you and the car in front regardless of speed - not so great when Audi/BMW drivers feel the need to be in your safe braking distance!
Christ knows what other things are available on the car version!
The following 1 user says Thank You to Tree for this post:1 user says Thank You to Tree for this post
• gotoberlin
Threads: 48
Thanks Given: 4
20
The old WV Caddy we had at the office(replaced with a new last fall) also had auto lights.
We made d*mn certain it was never ever set to 'auto'.
The car is uniformed, so if you drove through an undersea tunnel without rear lights, it tended to cause angry comments in the 'dial in' section of the local newspapers.
('Driving lights' usually dipped beam, is mandatory here also during the day, but rear lights are only required during night driving. And tunnels... so you won't notice if it goes from 'daylight' to 'night' mode when you're inside the car)
The Auto lights on the new one aren't really any better.
