Threads: 7
Thanks Received: 3 in 2 posts
Thanks Given: 8
Just a query, is the sump guard necessary?, also how much gap is there between the guard and the sump? many thanks.
Threads: 41
Thanks Received: 405 in 362 posts
Thanks Given: 134
31
I had a steel one on for a while but I think it wasn't necessary , really depends what type of road/track you're using.. I still go up and down rough roads and don't miss it.
If you do fit one fill the gap between the sump and guard with foam or something , if you hit a large rock and the space between the guard and sump has stones in it then any large loose stones can be forced into the sump.
A hole in a steel sump can be plugged with a lump of wood to get you home but the alloy ones just shatter
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 43
Thanks Received: 42 in 37 posts
Thanks Given: 3
i think oldfella is meaning the plastic under engine cover. if so on my last berlingo it had one and it became a pain in the butt. it kept coming loose and hanging down. on the berlingo i have now it was removed before i got the car and dosnt seem to cause a problem.....much easer for oil changes ect.
The following 1 user says Thank You to landcrab for this post:1 user says Thank You to landcrab for this post
• Oldfella
