Threads: 24
Thanks Received: 39 in 35 posts
Thanks Given: 487
Hi guys..
Does anyone know if steel wheels from a 12 plate van would fit a 04..?
called Brian...
Thanks Received: 2 in 2 posts
B9 has typically bigger et-number than M59. (et 27 versus et 18) i think that if there's a problem it's that rear wheel is touching car body. find et number of your current wheels and compare it to new wheels. ET indicates the distance between the mounting surface and the geometric center of the wheel and it's expressed in millimetres. wheels are closer with bigger et.
