Fast idle
Hi
My 05 Berlingo non turbo diesel idles around 1100rpm. I've had a look and as per photo is this the screw that needs adjusting? I've put a coin to show exact location, also what should the revs be?[attachment=4753]
You need to check the fast idle settings first before touching that screw and even then you need to read the manual carefully for proceedure.
For what it's worth my experience is " that " setting doesn't usually need adjusting.
My 1.9 non turbo (2005) idles at around 1200 rpm, hot or cold. As it otherwise runs beautifully, I don't want to tinker with it. The last time I tried to do what should have been a relatively straighforward job, I messed it up and was off the road for 3 days while my local garage sorted it!
John
As geoff says fast idle problem.
The fast idle wax stat can pack up or if controlled by the ecu it works on vacuum via solenoids - the vacuum pipe can split and loose vacuum thus the vehicle stays in fast idle.
Ive seen loads of them do one of the above - easy fix
  • John B
We have had 2 Berlingos with the 1.9 DW* engine both from new and both have a faster idle speed than I expected but the first did 180000 miles and our current Romahome is jsut short of 100000miles with no engine problems
Yesterday 12:02 PM
Berlingo 2026
Yesterday 03:17 AM
10-07-2026 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
