[For Sale] M59 1.6 HDi Cruise Control Speed / Instrument Cluster
Very rare instrument cluster for the 1.6HDi M59, that supports Cruise Control. It's a modified KPH version with MPH dials from a P206. The KPH > MPH mods were done by Saskak, the display shows the settings and car odometer in miles rather than KM so is completely MPH friendly. I've removed the unit from my B59 (also for sale) where it was working fine for a few months.
The only potential downside is that the cluster had approx 142k miles when it was removed, this may get transferred to a car with less miles. I imagine that it can quite easily be modified, but Saskak could probably answer that better than me. I still have the original KM dials so it could be converted back again.
Open to Offers, PM me if interested.
I can confirm that the mileage on the instrument cluster can be lowered to whatever one wants. This does not mean that one can lower the overall mileage. The mileage will be copied from the ecu to the cluster with the first switch of the key. So, both will match.
One needs upa-usb (red programmer ver 1.3 works, maybe the newer also). Also,  a sop8 to dip8 adapter. The adapter clips on the cluster eeprom, no need to solder anything. I have a detailed pdf on which values need changing, somewhere on here.
I can provide more info if needed.
Cheers,
Saskak
[-] The following 1 user says Thank You to saskak for this post:
  • cancunia
Today 02:22 AM
removing front strut
Today 02:07 AM
Strut Top Mounts
Yesterday 07:58 PM
14-09-2026 09:27 PM
Rear seat belt breakage
14-09-2026 04:13 PM
12-09-2026 05:49 AM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
29-08-2026 08:39 PM
