Broken hinges and catch pop out window
Hi all
Just back from a walk to find that some lowlife ha broken into my car 2010 berlingo LR60AYU , Nothing of value was left in car and nothing was taken  Angry
They ripped out my drivers side rear pop out  window , Glass is ok but both hinges  and window catch snapped off
I have looked at the internal upper trim but i am confused on how to remove . also does anyone know what are the part numbers for new hinges and window catch and the
best place to source
Thank you
Sorry to hear about your misfortune. You could probably get some hinges and a catch from an ebay seller breaking a B9, or a main dealer.
Other than that take a look on :
https://www.catcar.info/citroen/?lang=en&l=
or
http://service.citroen.com/pages/index.jsp
If you put your VIN into either of the above, you should be able to identify the part numbers you need. You need to register on the Citroen site, but it's free.
Gloveboxdirect sell genuine parts for Peugeot, but they are generally the same part numbers as Citroen.
https://gloveboxdirect.com/peugeot/
Last Post: wbchevron
Today 07:34 AM
Clocks dropping out
Last Post: Micklew
18-07-2026 09:29 PM
air con
Last Post: magoo1
18-07-2026 04:56 PM
triangle light
Last Post: Buki
18-07-2026 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
