Threads: 21
Thanks Received: 36 in 34 posts
Thanks Given: 6
Hiya all again ive a 53 plate beringo Thk dw8 engine
Well just recently its been a pain to start when started it runs perfect allday without fault covered 500 miles this weekend in it
Ive changed fuel filter and checked for any leeks but cannot seem to find any
Im having to prime pump under engine to get it going in the morning before this it was perfect i just cant understand whats happened to it any advice would be Great
Thanks all Muply
Threads: 32
Thanks Given: 13
How old are the glow plugs?
Have you had a look at the connectors to them to make sure they are clean and there's no damage?
Threads: 147
Thanks Given: 263
11
Sounds just like some of your glow plugs need replacing. It is typical for the Berl to be a hard start first thing if some need replacement, especially since with the temperature dropping.
Threads: 3
Thanks Given: 1
iv e got same problem with mine glowplugs changed for new ones and checked they all workin but bein a real pig to start once started runs fine !
Threads: 21
Thanks Given: 6
Unsure how old glowplugs are but i will check today and get back to you all Many Thanks
Threads: 32
Thanks Given: 13
My wife's corsa diesel was playing up and two of the glow plugs were black, one was a little loose and the connectors to them were crusty and rusty.
changed the plugs and cleaned up the connectors with contact cleaner and it's been spot on ever since.
Either way, it's worth doing for the price of a set of plugs.
Threads: 21
Thanks Given: 6
Will have a good look the weekend or hopefully sooner just so cold outside Just another quickie when my berlingo gets just before fuel light its naughty power loss cutting out and just sluggish this is the reason i changed fuel filter any body else suffer from this or is it just me apart from these things its good as gold Thanks in advice Lads
Threads: 3
Thanks Received: 2 in 2 posts
Thanks Given: 1
mines same engine mate,
had exact same problem, black coming from exhaust after a struggle to start.
Changed glowplugs and battery as battery been on the blink too, and now starting perfect, but it would work all day fine, starting and stopping, just first start of every morning. Really easy to replace on that engine too.
