window wont close.
hi guys ive a 2005 2.0 berlingo. today the passenger door window has stopped working,its 1/2 way up. ive looked at the plug that goes into the door but that looks fine. havent looked at fuse because i dont know where it is or which one it might be. everything else on the door is working fine . any help would be great as i dont want to leave it on the road with the window 1/2 open.  taaa
first things first. Remove the door card and see if there is battery voltage being presented to the motor when you press the glass travel button. If so, then the motor has failed. if not, then work your way back until you find the switching problem.
If the motor is still good, then jump +12VDC directly to the motor to get the window closed for the time being.
[-] The following 1 user says Thank You to David_R for this post:
  • landcrab
i took the door panel off pulled around on the wires and window was working fine again.dont know what the problem was but its fine now.
(06-09-2019, 07:50 PM)landcrab Wrote:  i took the door panel off pulled around on the wires and window was working fine again.dont know what the problem was but its fine now.
The problem you can get is the motor can overheat and will stop working until cool again, it can be worse on other makes & models
Yet another ABS fault
Yesterday 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
Last Post: oldbury863
24-04-2026 12:42 PM
Last Post: LucyLeBingo
20-04-2026 02:42 PM
