Threads: 123
Thanks Given: 250
34
Maybe a turbo oil seal that's gone, or some loose pipes between the rocker cover & the air intake.
Thanks Received: 7 in 7 posts
Thanks Given: 1
How does the oil get outside of the intercooler?
Maybe also a small hole in the intercooler together with some seal that failed
Threads: 23
Thanks Given: 50
29
Check the the oil breather from the rocker to the air intake is fitted right might not have sealed , you need something like a catch tank to stop the oil go in into the intercooler .
Threads: 12
Thanks Given: 16
37
If you can find a garage with a smoke tester, you get the cooler tested for leaks very easily, I bet you it is faulty.
Threads: 27
Thanks Received: 15 in 14 posts
Thanks Given: 9
I had same issue with oil in the intercooler and connected hoses but not leaking it was just sitting inside it. Turned out to be the oil seal in the turbo.
Threads: 9
Thanks Given: 316
15
I would say intercooler has a leak, seen it many times and it makes it look like the turbo has gone but its okay.
