Threads: 21
Thanks Received: 4 in 4 posts
Thanks Given: 16
On of my headlights is misted up. Is there any particular reason this happens and how do I resolve it please?
2010 Berlingo Multispace 1.6HDi - Chipped
Thanks Given: 188
23
You have moisture getting into the headlight so first step is to find out why, could be a crack or possibly bulb cover not fitted properly letting moisture in. Once you have fixed that dry the headlight out with a hairdryer then refit bulbs and bulb cover.
Are we there yet?????
Threads: 21
Thanks Given: 16
Thanks, I've checked the bulb covers and they are in place. There are no signs of any cracks in the casing. If it the seal between the casing can I repair with some silicon smeared around the edge of the casing?
Replacements are from £80 and they might have the same problem so it is worth trying to repair.
Threads: 48
Thanks Given: 4
20
I had that on some H4 lights I bought for my GS way back in the mists of time.
(It came with non-H lights, so when I came across a pair at a wrecking yard, I bought them, even with defect)
I cut the old sealant away, all around the light, then replaced it with regular white bathroom sealant.
They held together for years, until the car was scrapped for unrelated issues.
Thanks Given: 188
23
If there are no obvious signs then I would do as you suggest and run sealent around the shell and glass join and go from there.
• old son
Threads: 123
Thanks Given: 250
34
I had a similar problem on my M59, there were no cracks or leaks in the unit. It turned out to be bad air circulation due to the vents at the back of the unit. I fixed it by taking the internal filter out of the vent. I've no real idea why it only happened on one side, but allowing air to flow freely in through the vent fixed the problem.
The following 1 user says Thank You to cancunia for this post:1 user says Thank You to cancunia for this post
• old son
