Will struts off a newer model fit a 2001?
New here so hopefully I'm posting in the right place Smile My trusty Berlingo got an advisory for a leaking shock on the last MOT. Rather than pick up two brand new ones (I'm guessing they need replacing in pairs to stop one side sitting higher than the other) I was just going to buy two complete struts from a breakers. I'm guessing I would need to get ones from a 2.0 HDI 800KG to match mine, but does anyone know if that can be off the newer MK2? Finding second hand parts for the MK1 is obviously getting harder due to the age
Your model is almost a mk2, they changed from mk1 to mk2 in 2001.(oct I think ?).  I don't think there was any great change in the suspension between models so they would probably fit without any bother.
Someone else may definitely know.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
The change was in 2003, and no, there's no difference between a Mk I and II (with the same engine and load specs) on those parts.
But honestly, I wouldn't buy those parts secondhand.
The strut doesn't govern the ride height the spring does, just buy one and fit the same spring and you will have no problem. If you buy second hand you don't know they are a matched pair one could be newer.
Yesterday 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
06-06-2026 12:29 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
