11-09-2019, 09:35 PM
hi so i have a 53 plate berlingo (m59) and the speedo isn't working
i have tried changing the speed sensor (prev owner done twice as well) and checked the plastic pinion gear.
i have also changed the instrument cluster with 1 from a 206 (same part number below the stoplight).
i have connected my phone to the ecu using a elm327 and torque pro app and the ecu isnt seeing a speed ether so its a issue before that.
i have just been out and reached behind the engine unplugged the plug from the speed sensor and pin 1 is getting a constant ground it also has a resistance connection to fuse 1 in the engine bay fuse box as i was following the wiring diagram linked below pin 2 has no connection to ground like i believe it should according to that diagram
https://www.berlingoforum.com/attachment.php?aid=316
could some one check that i am checking the pins correctly also does anyone know where the mm01 earth point is?? as if pin 2 is ment to be earth i believe that this earth point could be the issue but unsure why im getting earth on pin 1
i should mention that this all started when the previous owner had to get the gearbox changed due to hitting a speed bump and cracking the housing so i believe it would be something caused by the replacement
any help would be greatly appreciated as this is now annoying me
