Threads: 123
Thanks Given: 250
34
Maybe the spring cups/bearings at the top of the strut?
Threads: 48
Thanks Given: 4
20
Never hurts to check the shocks at the same time. Or any ball-joint nearby. After all, if you've got it up on stands and have the wheels off...
Threads: 5
Thanks Received: 15 in 10 posts
Thanks Given: 8
I found compressing the springs to be quite a challenge as they are very long. I had to go out and buy another pair of spring compressors to use in conjunction and even then it was a marginal process. If I ever need to do it again I will get the local garage to reassemble the strut as they have a big commercial compressing tool.
Threads: 5
Thanks Given: 8
Should have added that it was quite risky as there was so much pressure involved and I felt the clamps could easily slip. Bit like handling a grenade, and I am not normally the nervous type. :-)
Threads: 11
Thanks Received: 1 in 1 posts
Oh really? Looking at mine they don't seem that long at all? (600kg version)
Guessing they are compressed...
Threads: 123
Thanks Given: 250
34
My 2.0 springs were too much for my compressors, nearly had a major incident getting the strut nut off the top. Had to get the local garage to put it back together. Different models have different spring ratings though, so you might be ok.
Threads: 5
Thanks Given: 8
Yes, it was getting them down to the compressed length to get the top bearing assembly retaining nut and washers on that I found dodgy. I had to help the top few coils down using some woodworking clamps, not recommended though.
I have changed springs on other makes just using my two original clamps but the berlingo springs were something else.
Threads: 5
Thanks Given: 8
BTW, mine is also a 2L, hdi. :-)
Threads: 29
Thanks Given: 67
20
(12-09-2019, 09:23 PM)ArozNick Wrote: Oh really? Looking at mine they don't seem that long at all? (600kg version)
There's a ton of vehicle holding them down, when you are trying to get a new spring down to fit the top on it's a whole different story. I bought a hydraulic spring compressor just to do mine as they both broke at the same time. It's easier to cut the drop links off than trying to undo them sometimes but I do try to remove them first then resort to the hacksaw ans angle grinder.
