Aftermarket remote central locking
I'm confused!
Ok so I have purchased remote central locking from ebay. I'm trying to install it in drivers door.
I have managed to get it to work by wiring direct to the battery. I have 5 wire thick blue, thick green and thin pink, thin green, thin green/ yellow.
What I'm struggling to find is permanent live. I figure there must be one to power the door locks for keyed operation.
Here is where I have got to.
Thin pink, lock close / open signal
Thin green, sends message back to bsi if door is open.
Thin green/yellow, earth
So I would assume thick wires are live/neutral however I have no power.
This is the first time I've attempted anything like this.
If you have a M49 or a M59 there is a fuse box under the steering wheel where you should be able to pick a permanent live. A cheap multi meter would show which is  which.  Not sure about the later models.
Or the battery is a permanent live or the engine fuse box will have them
I would guess that the thick blue is live and thick green is earth but that's a guess.
I would be careful about connecting anything to the BSI especially if not really essential
No instructions or are they in Chinese ?
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
(21-09-2019, 01:19 PM)Boa83 Wrote:  I'm confused!
If your car has already an electric window or a remote central locking you should find life in the driver door.
There was a video on YouTube for "Citroen Xsara Mk2 How to Fit Universal Keyless Remote Central Locking Fitting Guide Instructions.mp4" installing a Chinese system.
If you are sure not having life in the door watch "Citroen xsara picasso keyless entry kit.mp4".
Booth working as a standalone unit not using a preinstalled remote control.
Regards Rolf
_______
Berlingo Blue HDI120 S&S Shine, 08/2016, KYANOS Blue Metallic
Yesterday 09:14 PM
Yesterday 03:21 PM
Last Post: JPCoetzee
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
