"Multi-function display unit"
I have an issue with the unit that displays the time and date.
It displays these without fault (after replacing the bulbs a couple of months ago) but, when I switch off the ignition, although the date and time disappears, the bulbs in the unit don't go out and so it just glows orange!
Its only just started doing this ( noticed the other night when I looked out the window and saw it lit up) and so I am now having to either pull out the bulbs or disconnect the unit every night.
Whats going on- do you think its a unit fault or electrical on the van side of things??
(22-09-2019, 03:29 PM)matt1 Wrote:  I have an issue with the unit that displays the time and date.
This happens to me as well, sometimes. I switch the ignition on/off again and the bulbs goes out. I have replaced the original 2-line display with 3-line from a Citroen C8, so I somewhat attribute this to the mismatch display.
IIRC there is a permanent live & a switched live to the MFD? Maybe there's a fault / short in the circuit board somewhere.
There are some threads on here about the MFD wiring so some searching may throw up the info you need.
Newbie
Last Post: Vmkst
Yesterday 08:48 PM
MyBerlingo App Service History
Last Post: Requiem
13-02-2026 10:43 AM
Mk 3 K9 blower not working
12-02-2026 04:57 PM
Diagbox 9.91 free download
Last Post: Slowmo
11-02-2026 06:29 PM
Last Post: Slowmo
11-02-2026 06:26 PM
» Replies: 29
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
