[Steering & Suspension] steering tracking settings?
Hi all,
        My 2012 multispace berlingo had previously worn its front tyres perfectly but since changing all four at the beginning of the year the fronts(more the osf) are wearing on the inside edges(it has had new springs and top mounts this year so presumably the tracking/camber has been affected. Does anyone have the settings (tracking, camber etc)for the front suspension so that i know what they should be set at?
many thanks
Camber is fixed, the only thing that’s adjustable is the toe using the track rod ends and rack ends, if you take it for tracking they will have recommended figures (for even the none adjustable parameters so should be able to spot if something has been fitted incorrectly also... for example sacks had top mounts you could fit two ways for power steering or not), but you can’t go far wrong with parallel or slightly tied in by 0.5 degrees
Sounds like it’s toe’d in a little far if it’s scrubbing the inner edges
Toe out wears the inner edge.
Emissions fault.
Yesterday 06:29 AM
10-05-2025 05:31 PM
Winter Tyres
10-05-2025 02:42 PM
Start stop on van
Last Post: Rhino2k
09-05-2025 10:28 PM
09-05-2025 09:34 PM
Insurance Shocker !!!
Last Post: Keefus.
09-05-2025 01:45 PM
Part of Dipstick Stuck
Last Post: Nice4dad
09-05-2025 01:25 PM
BSI central locking again
Last Post: stuffe
09-05-2025 09:24 AM
» Replies: 23
steering column bearings
07-05-2025 07:53 PM
Gen 1 cream interior cleaning
07-05-2025 06:28 AM
