Hello, i have an Citroen Berlingo 2013 van, and i already have rear parking sensors,i would like to install front parking sensors also, so should i change my control module from the parking? or i can install the wiring from the front parking sensors to my current control module? thanks, and where is the control module located?
Threads: 27
Thanks Received: 359 in 316 posts
Thanks Given: 58
18
(28-09-2019, 09:36 PM)Shanks Wrote: i can install the wiring from the front parking sensors to my current control module? thanks, and where is the control module located?
Do they have a module ? Most ones I've seen are operated by the reversing light in the rear. If you ran from that the front sensors would only be active when you are in reverse gear. Front ones would be active all the time unless you fitted them on a switch.
