Threads: 26
Thanks Received: 29 in 14 posts
Thanks Given: 14
Hi all,
Does anyone have any information regarding the torque settings for the sway bars/anti roll bar link rods? I can make a semi reasonable guess but the correct information would be helpful.
I’m assuming, of course, that there is a torque setting value and not just give it loads of welly!
Thanks in anticipation,
El Berlingo
Threads: 123
Thanks Given: 250
34
The Haynes manual is on here somewhere, there's a section on torque settings in there IIRC. If it's the links to the struts, I normally just make them 'tight' by feel, none have yet come loose. Somewhere online there will be generic torque ratings for a given thread size you could use as a guide,
Threads: 26
Thanks Given: 14
03-10-2019, 02:26 PM
(This post was last modified: 03-10-2019, 02:39 PM by El Berlingo.)
Hi,
Thanks. Tried to find Haynes manual here but unable to do so. I’ll take another look.
Cheers,
El Berlingo
Threads: 26
Thanks Given: 14
03-10-2019, 02:49 PM
(This post was last modified: 04-10-2019, 11:02 AM by El Berlingo.)
Hola,
40Nm seems par for the course! Seems low, 110 for rear shock absorbers! I think I’ll go for around the top end.
El Berlingo
