[Warning Light] Electrical circuit fault
Battery light came on today with a lovely little ping noise as well as a warning in the display saying "electrical circuit fault"
Van is 5 years old covered less than 20k miles - surely can't be the alternator can it?
Battery perhaps?
Light went out after 10 mins and then came back on about 10 mins later
Any thoughts would be greatly appreciated.
Maybe a loose connection near the battery or an earth lead from the battery. Easiest check is with a multimeter or voltage tester and see if the battery is charging when the engine runs. Beyond that, I'd suggest getting a diagnostic check, probably Diagbox would be best to read any Citroen specific fault, maybe something like the Android Torque app would do the job too.
  • WeeTam
(07-10-2019, 06:31 AM)cancunia Wrote:  Maybe a loose connection near the battery or an earth lead from the battery.  Easiest check is with a multimeter or voltage tester and see if the battery is charging when the engine runs. Beyond that, I'd suggest getting a diagnostic check, probably Diagbox would be best to read any Citroen specific fault, maybe something like the Android Torque app would do the job too.
Thanks Cancunia I have ordered a tester to do just that.
I was unaware there was an App that you could do checks with so will look into that also.
You should be getting 14 volt from the battery with the engine running, to test a bad battery it needs to be load tested.
[-] The following 1 user says Thank You to V6BOY for this post:
  • WeeTam
(07-10-2019, 12:49 PM)V6BOY Wrote:  You should be getting 14 volt from the battery with the engine running, to test a bad battery it needs to be load tested.
Ok thanks for that info.
Hi Guys. Did this get resolved? I am having the exact same issue.
(06-02-2022, 06:25 AM)Nigel.Lockett Wrote:  Hi Guys. Did this get resolved? I am having the exact same issue.
Have you checked to see if the battery is charging correctly when the engine is running as described above by cancunia & V6BOY
SOLVED: P20F6 fault
Today 07:18 AM
Coolant
Last Post: Martinze
Yesterday 08:24 PM
Leaking windscreen or aerial
15-04-2026 08:50 PM
