Threads: 11
Thanks Given: 2
08-10-2019, 11:38 AM
(This post was last modified: 08-10-2019, 11:38 AM by Jake97.)
I’ve got a 65 plate Berlingo with the 7inch touchscreen DAB but I hardly ever have any signal for the DAB. When I rescan for channels it usually finds quite a few but only 1 or 2 stations work for 30 seconds or so then cut out. I rescanned the other day and only found BBC channels and it won’t pick up anything else now. Any ideas to get better reception? Or even how to do a factory reset to see if that helps. Thanks
Threads: 20
Thanks Given: 7
14
Sounds like its the aerial base thats packed in - i had to replace mine once on my 65 plate and numerous people on here have had issues with them.
Its about £28 from citroen and takes about 30 mins to replace. You will find it has three wires coming off it whereas the one in the vehicle will have two. Don't worry about that as they are all sold now with the GPS antenna as standard.
The following 2 users say Thank You to Tree for this post:2 users say Thank You to Tree for this post
• Jake97, Matt Haigh
