Threads: 123
Thanks Given: 250
34
I was looking at an MoT history earlier for a Toyota Hiace. It's twice failed on emissions, then passed with no increase in mileage. I looked at another which had exactly the same problem.
I'm wondering how things were fixed without any miles, if it was once then perhaps something was replaced, but twice makes me wonder if it was snake oil, or maybe they simply hadn't warmed the engine up before testing.
Threads: 43
Thanks Received: 413 in 370 posts
Thanks Given: 137
33
10-10-2019, 03:03 PM
(This post was last modified: 10-10-2019, 03:04 PM by brodfather11.)
Was the date the same ? . There may be a well known cause and simple cure that enables them to pass the same day.
That could be done without mileage being clocked up.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 29
Thanks Given: 67
20
They take it outside and sit with their foot on the accelerator for 5 minutes to get it hot then put it through again usually.
Threads: 9
Thanks Given: 316
15
Millers - tip the full bottle in and then go and give it a good thrashing in 3rd gear = job done
Threads: 26
Thanks Received: 29 in 14 posts
Thanks Given: 14
Hi,
My Berlingo failed its ITV ( Spanish MOT ) through emissions failure.
Bought some additive to clean Diesel engines ( Redex, 2CV, Wynns, et al) and gave it large revs down the Autopista . Straight back to test station, passed with flying colours. I suppose this is a ‘Spanish Tune up’!
El Berlingo
Threads: 3
Thanks Received: 2 in 2 posts
Thanks Given: 10
11-10-2019, 06:07 PM
(This post was last modified: 11-10-2019, 06:08 PM by John B.)
Before I bought my Berlingo I had a Ford Fiesta 1.8 diesel van, which failed its test on emissions. My local garage put a gallon of petrol in the fuel tank, then told me to give it a good run giving plenty of revs for half an hour. It ran fine and passed the retest.
John
Threads: 123
Thanks Given: 250
34
Yep, I'd be wary of putting petrol into a modern diesel. I've heard about putting a high dose of Millers or similar into the fuel filter bowl, easy enough to do on the 2.0 Berlingo.
