P0171 System Too Lean
P0171 System Too Lean (Bank 1)
Van just threw this code on the motorway. Engine doesn't seem to be any different (not obviously rough etc.) so hoping it's just a bad sensor or something.
I had also put in some fuel injector cleaner stuff, so possibly that's revealed a fault or clogged the fuel filter with gunk, or something?
Advice appreciated - on googling, I can't find any posts about this code on a Berlingo specifically..?
1.6 Petrol, btw
Check the coolant temp (lean will run hot), check the spark plug electrode colour to see if white or brown. Maybe change the fuel filter in any case.
Maybe the MAF?
https://www.obd-codes.com/p0171
What does the spark plug electrode colour indicate? I was under the impression that a bit of brown was normal..?
Yeah I was planning to change the fuel filter anyway, no record of when it was last changed so assuming it's overdue.
Stupid question, but does the petrol Berlingo even have an MAF? I can't find any reference to it in Haynes or parts websites.
(12-10-2019, 12:46 PM)SteakAndAle Wrote:  What does the spark plug electrode colour indicate? I was under the impression that a bit of brown was normal..?
Brown is normal on the plug, so if it's white it's too lean, or black is too rich. No idea about the MAF on a petrol engine, it was just what I read in the link I pasted. Looks in any case to be the oxygen sensor in the exhaust that's complaining, another possibility is maybe that's failed.
Ah, OK.
I cleared the code before heading home today and it didn't reappear (~140 miles). I'll change the fuel filter as planned and have a look at the lambda sensor while I'm under there anyway.
BSI
Last Post: Zion
Yesterday 06:47 PM
» Replies: 26
Dropped a valve ?
Last Post: james1089
Yesterday 05:34 PM
» Replies: 24
HELPPPPPPP, citroen extended warranty team rejec...
Yesterday 05:20 PM
Add blue / engine fault light
Yesterday 05:13 PM
Newbie
Last Post: Rosemerry
Yesterday 02:48 PM
Electric probs - where to start
Last Post: Zion
Yesterday 10:58 AM
Replacing wings
Yesterday 10:01 AM
Sliding door rattle
Last Post: melpa
Yesterday 12:57 AM
New to Berlingos - Impressed so far!
Last Post: RichCowell
29-09-2023 11:03 AM
Appropriate Jumper Battery
Last Post: Abaddon
29-09-2023 09:38 AM
