[Brakes] Accident damaged Berlingo abs fault
Hi all, help needed please from more knowledgeable folk!
I recently purchased a 2016 Berlingo 1.6 hdi with front end damage. Unfortunately the plug that connects  to the abs pump was damaged so that the pins were pulled out of the circuit board.  Abs and stability control/traction control? light is lit and the touch screen reports a brake fault.
I managed to find a replacement abs pump from a Citroen Picasso but it has  different numbers on the abs ecu.265 951 525 & 99001 s0174.
The van eventually went into 'economy mode' and refused to even try to start with the damaged ecu fitted. It now starts fine with the Picasso Ecu plugged in but is still showing an abs fault...
On the original Berlingo ECU the part numers are 2265106515 0265956416
Would it be possible to code this ecu to the Berlingo van - I bought this hoping it will do the job ..
https://www.ebay.co.uk/itm/FULL-Chip-Lex...2749.l2649
I have an ancient windows xp laptop that I'm hoping will run this. Heard stories about the installation being a nightmare and my computer skills aren't great!
Am I just wasting my time and do I need to find a matching numbers ecu ?
Thanks in anticipation of any replies, all help appreciated Smile
I plugged in the Picasso abs ecu ..still have an brake fault showing on the touchscreen but I can now start the van to move it around the yard.
Wondering if these chaps are good ?..the ecu numbers match mine Smile
https://www.actronics.co.uk/abs-ecu/bosch-9-0-esp
(16-10-2019, 02:02 PM)greenclaws75 Wrote:  I plugged in the Picasso abs ecu ..still have an brake fault showing on the touchscreen but I can now start the van to move it around the yard.
No good - they can't repair a cracked  circuit board  Sad
Don't suppose anyone knows where I can get an abs ecu with these numbers ? Huh
Attached Files Thumbnail(s)
Last Post: Alberts elbow
Yesterday 10:11 PM
Yesterday 09:32 PM
Yesterday 05:46 PM
Yesterday 05:17 PM
Potential Purchase!
Yesterday 03:03 PM
Diagbox 7.57 download
08-03-2026 09:13 PM
Air filter box removal
Last Post: Harrythephot
07-03-2026 11:03 PM
Berlingo undertray
07-03-2026 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 07:07 AM
