Thanks Given: 14
fallen at the first nerdal ...,? about specific variant of berlingo , mine is classed as berlingo first.... my year of production is 2009 ..., am i a M59 ?
Threads: 123
Thanks Given: 250
34
Look for pictures of Berlingos. Chances are you have an M59
Threads: 17
Thanks Received: 6 in 6 posts
Thanks Given: 64
As I see it , there are three types of Berlingo - the M49 ( pre facelift i.e . narrow headlights );
the M59 ( post facelift i.e . bug eye headlamps ) - these are variants of the same vehicle & are both Berlingo Firsts ( ? ).
The later & larger modern version ( post 2008 ? ) is a completely different vehicle & is presumably a Berlingo 2 / Second ( ??? ) .
Thanks Given: 188
23
As I understand it the name berlingo first (M59) that citroen used on the van run out when they brought the new B9 version out in 2008/9. It was a basic van and cheaper than the new B9 and the oldest one I have seen had a 2010 plate on it.
Are we there yet?????
Threads: 9
Thanks Given: 316
15
I have a 2008 berlingo first its just the last of the mk 1s or a M59 model - the firsts came as a base van but you could upgrade with every option available on the enterprise so they will all be different specs.
• lonsometossa
