26-10-2019, 11:47 AM
Hi all, help needed please to get my van back on the road and restore my sanity!
I have a Berlingo 16 plate van with a damaged abs module.
So far I have obtained a matching numbers abs module from Ebay and bought a copy version of Diagbox.
With this setup I could connect to the van (the earlier diagbox v7.02 didn't recognise the engine ecu) but the ABS module comes up as a red 'No communication' message.
Is there an abs fuse that could have blown as the original abs module was damaged in the accident ?. Does the system have to be bled and piped up to connect . There are two permanent 12v feeds at the ecu plug and two earths.
Tried another spare abs module off a Citroen Picasso but that wont talk to diagbox either..
I managed to update my diagbox to v7.57 after watching the Chinese video again and now I can clear all fault codes except those for the missing headlamps.
Engine management light is now off.
Unfortunately the ABS module is still reporting as 'no communication' so I can't access it to find fault codes or change the configuration.
Any ideas on what to do next before I order a new abs module from Citren £££?. Is it worth updating diagbox to a later version ?,
Thanks in anticipation of any replies..really don't want to order an abs module from Citroen £££ if it's just a wiring issue
![[Image: icon_cry.gif]](https://frenchcarforum.co.uk/forum/images/smilies/icon_cry.gif)
- [url=https://frenchcarforum.co.uk/forum/posting.php?mode=quote&p=624044][/url]
