Interior lights
Hello,
I think I have a problem with my 200 Berlingo van ... the two interior lights both have 3 options:
1) 0=always "off"
2) Idea Alwayw "on"
3) Symbol fo door: "on" when door opens etc.
Option 3 does not work in my car for both ligths ... i can only put them on and off manually ... is this normal? Maybe a burned fuse? Anyone? Huh
Its the door switches that often stop the interior lights coming on when door opens.
The early Berlingo's had them not sure about your model ? of Berlingo. . the later models had the switches built into the door lock I think.
Its a easy job to change the older ones , they were mounted between the door hinges and worked by earthing the interior lights. They are cheap enough to buy and easy to fit. 1 screw holds them in,
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
(27-10-2019, 01:13 PM)brodfather11 Wrote:  Its the door switches that often stop the interior lights coming on when door opens.
Hmmm, not sure if i understand ... mine is a 2005 van (Berlingo 1 facelift). I'll check the hinges ...
Played around with the switches ... got it working again. Smile
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
