Threads: 5
OK, I just noticed that the fan in my car (with airco) only seems to works in position 3 and 4. In position 1 and 2 i can't hear anything working ... is this normal, or a known issue?
(Berlingo van 2005 2.0 HDI)
Threads: 5
Thanks man! Just browsed this forum ... and yes a common problem ... I think I'm going to change that resistor.
Thanks Given: 188
23
Test it when you get the pack out don't just assume its faulty.
Are we there yet?????
Thanks Given: 188
23
Not sure if its swapped round on a left hand drive model perhaps you need to look up under the dash from the passenger side. There is a piece of lining/cloth trim that you have to let down by removing 3 plastic fixings and then look up under the dash towards the centre of the car. Have you got a workshop manual that may help locate it and give you a better idea. You can download a manual on the site somewhere.
