Heater blower relay location on mk 1 berlingo 2008 plate
Hi new to this site but wondering if anyone can help me .
I have a 2008 berlingo 1.6hdi mk1 and the heater is not working .I have replaced the blower heater resistor mounted in the fan which is located in the passenger foot well which still doesn't work so I have bought the relay instead but I cant find where it goes I've looked everywhere .when I look on youtube it says it's a green relay I should be looking for but I cant see anything of the sort plus the relay I have is black .can someone help? Many thanks gareth
If yours is a M59 model not the newer B9 series not sure on relay location but have you looked in the engine bay fuse box. There are various relays in there and also check all fuses. Are you sure the heater motor is ok a few have had the motor shaft seize.
Thanks I'll take a look when it stops raining and get back to you .thanks
Hi I've had a look at all the fuses and they are fine. I cant see any relays there and had a good look all around.im really stumped!
Today 12:29 PM
Yesterday 07:46 PM
Last Post: CB-K9murph
Yesterday 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
