How do you remove the inside lower panels of boot space?
Needing to remove the rear panels inside the boot - trying to track down the water ingress.
Carpet it out but I can't work out how to remove the panels - brute force seems to be the way but I'd rather not damage the panels.
So what is the correct way to remove them please?
Having just finished watching Life of Brian, I thought Brian would be too serious a username for myself!
2014 Peugeot Partner Tepee Outdoor 115bhp
boot panels pressed clipped in..........you should not break anything..........
Ta, so I get my finger behind it and just pull out?
https://www.youtube.com/watch?v=TyXPgijQoyk
(03-11-2019, 01:44 PM)gazahull Wrote:  boot panels pressed clipped in..........you should not break anything..........
try the youtube above
All sorted, thanks...and as suspected, plenty water in there...back of panel is soaked so drying that. The wee black box has plenty water on it - now dried. Wiring seems to work but damp.
I suspected the water was coming in via rear light cluster but that is totally dry...so really unsure where the water has come from...surface of car above the black box thing is all dry so I'm really confused.
Will leave panel off for a few days and run air con to help dry the car out.
Driver side rear panel also removed and that is all dry, so just passenger side getting water in.
(04-11-2019, 07:55 PM)BigiusDickius Wrote:  All sorted, thanks...and as suspected, plenty water in there...back of panel is soaked so drying that. The wee black box has plenty water on it - now dried. Wiring seems to work but damp.
also might be leaking thru rear window seal.......... leak coming from above.......also try... open rear door, nearside top left...where the flexi wire cover is.....make sure its well sealed......most possible culprit
(03-11-2019, 04:05 PM)gazahull Wrote:  https://www.youtube.com/watch?v=TyXPgijQoyk
Thanks for posting this video. Hopefully I won't ever need to do it, but am amazed at amount of wiring behind panel.
is the wiring still there where the torch was fitted to early cars
Unsure...I don't know what I'd be looking at to confirm.
Plenty wires and all resting on a plastic self-styled thing. It is the shelf that is soaked.
I'm going to seal the runner for rear door and also put more sealant inside against the body work.
20-07-2026 02:51 PM
Clocks dropping out
Last Post: Micklew
18-07-2026 09:29 PM
air con
Last Post: magoo1
18-07-2026 04:56 PM
triangle light
Last Post: Buki
18-07-2026 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
