Oil seal timing belt wheel
Anyone can tell me what kind of seal there is behind the top wheel on the timingbelt ?  Looks like there is a oil leak from there...
Its a 2008 1,6ltr hdi 75 hp engine....
Lennis
You mean the camshaft seal? Just a normal lip type seal.
  • Lennis
(04-11-2019, 10:25 PM)polar Wrote:  You mean the camshaft seal? Just a normal lip type seal.
Thanks for the answer..
Yeap the Camshaft seal ..  You know if this is easy to change ? something i realy need to be aware off  ?
I was thinkin maybe to take the whole engine out, but that might be a litle overkill for just that lip seal, but like berlingo engines are theres probobly some more gaskets nees to be changed also..
Not done it myself, but I'd be surprised if the engine needs to come out. The exact procedure will depend on what version of the 1.6Hdi engine you have. If it's 2008, it'll almost certainly be the 16v.
This should give a hint of what's needed..
https://www.youtube.com/watch?v=RdeQtNmqcek
AFAIK, the seal comes separately, no need to buy the whole kit as in the video.
  • Lennis
Eolys replacement tank
Last Post: Harrythephot
14-08-2026 12:02 PM
14-08-2026 10:27 AM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: stu76
12-08-2026 05:41 AM
Last Post: BigVtwin996
09-08-2026 12:10 PM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
