06-11-2019, 01:07 PM
This is on our Dispatch and not Berlingo but I figure they are probably about the same and I like this forum.
The drivers door lock has started to get a bit stiff recently so we decided to spray it with WD40 and since then it has gone all loose and doesn't unlock the door properly, you really have to mess about with the key turning it both ways to get it to unlock, sometimes you have to unlock the rear doors and open them to get the drivers door to unlock. It also now locks itself as soon as you shut the door where it didn't before so I presume the barrel is now staying in the locked position.
Its not the key as the back doors and ignition still work perfectly, also my mate has managed to loose the remote key when he was down the pub getting pissed one night, I can't find the key code card to program a new key and its about £80 for a new key with the code number and takes a week or so to arrive so we are down to the last key at the moment.
Is this a common problem with door locks on Citroens?
So yes the key is worn a bit and a new sharp key may work, but a barrel and a new key will have it perfect again
